Just reporting in while at the Yreka Public Library...the '91 Ford Festiva L("The FestivaL Car") seems to be running about as always, traveling familiar roads and such. Coming from Berkeley at about 75-80 mph getting over 38 mpg.
The cooling fan seems to be a barrier to air-flow when operating above a certain mph which seems far less than 50 mph. So, a manual overide would be advantageous rather than fixing the thermostatically controlled switch to the relay.
I've been pulling the plug to turn on the fan, thus monitoring the various modes when running or not, at speed or not, in various outside temperatures mostly below 79 degrees farienheit.
I'd noticed an extra washer or whatever the metal gasket at the base of a spark-plug is called; when cleaning and gapping the plugs in B'ham a couple weeks ago or so. That plug had a more whitish color by far than the normal/healthy looking three plugs further from the distributor. I don't know if this may've had an effect on my mileage?(previously)
The whole mileage question likely has been fluxuating due to various wind paths and such is a pretty good theory?
Take care all.(FOR THE REST OF US!!!)
88' LX EMERGENSTEVIA
