ok thanks il look into it
fms cams
a little off topic but will the fms cam work in a 2nd gen b6?
Mike, AKA the sasquatch
^ yes.
you'll not have issues with coil bind.Trees aren't kind to me...
are the heads interchangeable, with one having the mech. fuel pump and the other not?Originally posted by blkfordsedan View PostYes. But I don't think you have to change the head if your '88 is OK. All you should have to do is use the shaft & rocker assemblies off the '92 head. I believe it should bolt on to the '88 head without issues (once again, someone correct me if I'm wrong!). I do not know if the springs in the '88 head are weaker or more susceptible to coil bind than the later model EFI springs. You should double check for coil bind before firing it up.Joey Richard Jr.
1991 Ford Festiva L; died but donated all her organs
1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
Quality is Job 1. Together, We Can Save Lives. Ford.
i dont see where to click to edit my post, but I wanted to change it to ...
are the heads for the carbed and efi interchangeable, with one having the mech. fuel pump and the other not?Joey Richard Jr.
Do the newer heads have a bolck off plate where the older carbie heads have fuel pumps??
I don't think so.
The cam will fit any b3/b6 8 valve motor....
I have used my competion cam on a set of HLA aspire arms with no ill effects...---------------------------------------------------
yeah but Wes, what springs were you using?
and yes there's a block off plate on the efi heads that will accept a carb fuel pump.Trees aren't kind to me...
