Nice BP G25MR w/ hydraulic clutch on Cardomain
  • Nice BP G25MR w/ hydraulic clutch on Cardomain
    Check this guys festiva
    The interesting thing is that he used the escort gt tranny with the hydraulic clutch.
    matt
    Hey Matt...at least he gave you some credit for your wiring info! :wink:
    Kevin
    '93 L (BP{T} Sold
    '90 L Plus Sold
    '94 Mercury Capri XR2 sold
      He's got some good info on the swap.
      The Festiva Store
        I was looking at that page.He does have good info in there.
        Matt and I are on he's friends list!
        06 vw Bora
        09 Nissan Versa
        fastest B6T is back!!!
        http://www.cardomain.com/memberpage/785928
          what is the difference between a hydraulic clutch and a standard?
            hydraulic vs. cable clutch
            A hydraulic clutch works like your brakes, when you push on the clutch pedal a pushrod on the pedal pushes in on the clutch master cylinder and forces fluid to the slave cylinder that's on the tranny and it causes it to disengage.
            A cable operated clutch, is easier. The clutch pedal pulls on a cable that's connected to a bracket on the tranny, and that disengages the tranny.
            http://www.cardomain.com/ride/2162509
            First known g25mr with Hydraulic clutch swap
              converting to hydro is pretty easy, reworking the pedal was a pain but had to be done lol... you would prolly have more room for a radiator if the front trans mount wasnt so large because it fits over the slave cyl, i had to remove the rad support right over the crossmember in order to put my mount in there...
              all in all though, i have to admit when ive got it setup right it doesnt even feel any different than the cable clutch... not to mention the power of the bp and the EGT's gearing? im psyched to get this project completed by the end of the week so i can get out there and kick some butt!
              he has really good info on there, i used alot of it on my own swap along with matt's page for wiring. only thing i did differently from them was my mounts are solid and i cut and pushed back the frame rail on the driver side for the tranny instead of bash it in lol...
              1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
                Hydraulic Tranny
                Hey, that's awesome man you got it working!! Glad that I could help you.'
                Have fun beating up on everything out there, I know I have
