I have a b3 engine & I wish to time the engine correctly using a test light. The timing mark on the timing belt cover have 2 marks. One is T and the other is 10. Also the pulley have 2 slots. Which one should I use for the 10 degrees timing mark? I have used some white paint to mark the positions. Have I done it right? Also the iso connector which one is it? See attached photos for the timing and the iso connector.
Thanks
Thanks
