Had to take the White Tach Cluster out. Frankly, it crapped out!! No ones fault. But it gave me time to go over my old cluster and clean it up. Took out all the lights and cleaned them. Got some plastic cleaner and worked on the face. It cleaned up to an almost acceptable standard. But the real work went in on the dash light bar. Inside, there are four (4) tiny lights behind a green plastic bar. I took off the bar, cleaned it and cleaned each light and the white backing. Returned the completed unit to the car. What a difference!! Clear and bright, almost. About 45 minutes work. Well worth it.
The Tach Cluster looks better, but my old cluster is more accurate with bigger faces and wider dial swings. Will go to a traditional tach unit on the dash. Plenty of room for it. This is my experience and is provided for information only !!
"Drive On...ARMY"
"Drive On...ARMY"
