Hello festiva owners. I would like to know if there is anyone out there who has, or knows someone who has had Airbag Suspension kit installed on their festiva. I got a complete kit ready for install from The Hoffman group, average cost around $2500.00 depending on how much or how little you want included. This one has two compressors, and the controller with 8 presets. I also got two spare airbags,one for front and rear. My first install estimate is about $2000.00, because the installer says both the existing front and rear suspension has to be removed from the car then refitted. The kit requires no cutting, welding or modification of ANY kind. Its bolt in, run the air hoses and wire in the controller. I just would like to avoid being overcharged if thats possible. I have also spoken to Tech support at hoffman and their info is forth coming. Any input will be helpful. Thanks.........T
Need advice on Airbag suspension install
location?Trees aren't kind to me...
$2000 sounds a little pricey to me....my opinion ....-Greg
Redneck Engineer
FOTY - '09
It would be easier to use aircans instead of bags. You would be able to replace the entire strut assembly with the aircan and adjust your camber correctly for your desired ride height and be all set.-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
They both have had a festy on air.
Poverty produces creativity
