escort gas door popper
  • escort gas door popper
    anybody know how to take one out? im going to pullapart sunday and i know they got some
    it'll do the 1/8 in 13.7, spin tires, and make all my drunk buddies giggle.
    "I like a Festiva because there's less car to get in the way of the driving experience"
    not sure if an escort popper will work. Look for a tracer or a 323, 89 to maybe 91
      Wait.. you can get gas-door poppers that work??
      How hard is the install?
        It is a cable operated lever and popper
          well you know how to get em out real easy? im assuming they work by cable
            nope....I think stefan has put them in a car
              He lives down the street from me... Unless he installed them on his old escort wagon I'm pretty sure he doesn't have 'em in his 90LX... his 89SX came with 'em factory though.
                Getting a trunk or gas lid popper out of a 323 or Protege will involve removing the interior carpet and pieces on that side. If you find a car with some of that already done, it could be easier.
                I've never removed one myself, but upon removal you should see how it would be installed in a Festiva. Shouldn't be too difficult, but perhaps time intensive?
                I can't recall if you need to drill an extra or larger hole in the Festy gas inlet wall (under the lid where the rubber bumpstop/latch is) or if the bumpstop/latch hole will provide the necessary hole itself when swapping parts.
                Also, I'm not sure if the cable runs just under the carpet, the rocker cover, or has to be run through the body/rocker panel itself. I do recall that the cable loops around behind the gas door area inside the body and goes into the bumpstop/latch area to effect the remote unlatching.
                  Bah, this is way out of my abilities...
                  I guess I'll have to open the door and unlock the gas door like everyone else lol
                    They were offered on 121s and prides. I have this set from a pride. They are a direct fit on a festiva. If you look inside the gas door there is a place for the cable to come through. Also on the latch and hatch latch there is a slot for the cable to connect.
                    It requires removing the plastic on the left side and pulling the door sill plate and pulling the carpet back. I have not seen the escort ones, but maybe you can use these pics to compare.
                    '89L 110k mi. BP/G swapped
                    '90 F250 4X4 108K mi.
                    '13 Kia Rio 5 LX 70k mi.
                    '18 Kia Soul 40k mi. Daily
                      Looks pretty straightforward. I think the hardest part would be removing the cable and parts from the donor car, because most of us aren't as familiar with 323s as we are our own cars.
                      It would mainly be a time consuming job, that's all. Not beyond most or our abilities.
                      David, am I right in thinking those remote cables are one unit? That's what it looks like.
                        Yes its a unit. It bolts into the floor brace to the left of the drivers seat.
                          So if you don't want to hook up the hatch popper, you can just leave that cable coiled up under your trunk plastic, right?
                            Durr I forgot they made LHD 121's... Stefan's SX has that thing but it's a RHD and they'd be on the passenger side lol
                              Just a note, the cable doesn't open the hatch it only unlocks it. But you can use the ones from a 323 or tracer. They are practically a bolt in.
                              93 GL modyfied!!!
                              :fish:
