I need four metric bolts M12 1.5 about 3-inches long (~75mm) to get my bp on an engine stand and haven't been able to find fine thread metric bolts locally. Does anyone have any ideas as to where I can find some?
Metric bolts for engine stand
if you cant find any use some smaller ones that slide thru the holes... thats what i did on 2 of them... the top ones i used the ones that hold the motor to the trans...
Mike, AKA the sasquatch
McMaster-Carr catalog has M12 x 1.25 bolts up to 120 mm (4-3/4 in) length
URL is: http://www.mcmaster.com/#cap-screws/=4ueo78
Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
In memory of Dean Allen - V8 Festiva 1955-2010
Thanks, I guess I should have clarified that I found them online but paying $20 for four bolts (with shipping) that I won't use again somehow bugs me
If I can't find them locally and the smaller diameter bolt doesn't work, I'll have to buy them online.
Oscar
I live far away from you but usually one of the parts stores will have them.
They have a bin in the back. I think "advance-auto" was the one. That might be called "checkers" or something where you are.
Or go to the u-pull yard and look around...brake calipers maybe.
Thanks for all the godd ideas guys. Brian, thanks for the store name. There is one very close to my work. And the price of each bolt is $1.71 compared to $5+ elsewhere. I'll stop by at lunch time and order them since they are out of stock. Hopefuly, I'll have them by Friday so that I can work on the engine this weekend. Thanks guys!Oscar
