Metric bolts for engine stand
  • Metric bolts for engine stand
    I need four metric bolts M12 1.5 about 3-inches long (~75mm) to get my bp on an engine stand and haven't been able to find fine thread metric bolts locally. Does anyone have any ideas as to where I can find some?
    Oscar
    if you cant find any use some smaller ones that slide thru the holes... thats what i did on 2 of them... the top ones i used the ones that hold the motor to the trans...
    Mike, AKA the sasquatch
      ^ How did you keep the threads on the block from getting messed up using the smaller bolts? I'm thinking that maybe a M10 1.5 would help prevent the ruining the block's threads.
      Oscar
        McMaster-Carr catalog has M12 x 1.25 bolts up to 120 mm (4-3/4 in) length
        URL is: http://www.mcmaster.com/#cap-screws/=4ueo78
          Thanks, I guess I should have clarified that I found them online but paying $20 for four bolts (with shipping) that I won't use again somehow bugs me If I can't find them locally and the smaller diameter bolt doesn't work, I'll have to buy them online.
          Oscar
            I live far away from you but usually one of the parts stores will have them.
            They have a bin in the back. I think "advance-auto" was the one. That might be called "checkers" or something where you are.
            Or go to the u-pull yard and look around...brake calipers maybe.
              ^ Good ideas. Thanks! I'm going to look at brake caliper bolts since I have some calipers laying alround but I think the thread pitch is 1.25. I hope I'm wrong
              Oscar
                i used my stock bell housing bolts on a harbor freight engine stand
                  I didn't know they were long enough. I don't have the stock bolts but could easily pick up a set at a junk yard. Thanks!
                  Oscar
                    Go buy some all-thread rod, cut to length and put a nut on each end. 3/8's diameter will work. 7/16's is still small enough to slide through your existing threaded holes.
                    Dirt cheap.
                      If you have a local Fastenal store (there are everywhere) They will either have or can get within a day the bolts you need.
                      93 GL modyfied!!!
                      :fish:
                        Thanks for all the godd ideas guys. Brian, thanks for the store name. There is one very close to my work. And the price of each bolt is $1.71 compared to $5+ elsewhere. I'll stop by at lunch time and order them since they are out of stock. Hopefuly, I'll have them by Friday so that I can work on the engine this weekend. Thanks guys!
                        Oscar
                          Glad I could help!
                          93 GL modyfied!!!
                          :fish:
