i have a aluminum head i want to clean up, other then brake cleaner is there anything else that is good to use and safe on aluminum to clean up the burnt carbon? i think i remember someone saying oven cleaner?
need suggestions what to use to clean carbon?
Good carb cleaner with Toluene does a good job. Get the $1.25 stuff at Wal-Mart. A good washing with Castrol Super Clean will break alot of it up. I've also used acetone, and lacquer thinner works well too. Gotta be careful with oven cleaner, I've seen it turn aluminum black.
Zanzer is correct about the oven cleaner it's usually sodium hydroxide and will chew-up aluminum if left in contact for long.
Better with some petrochemical derivative and apply repeatedly till clean.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Wire brush.-Greg
Redneck Engineer
FOTY - '09
I used purple power to clean one of mine up, and it worked great.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
if the head is off the motor just send it to a machine shop and get them to "hot tank" it... it cost me 25 bucks to do my whole motor... i didnt have to clean a single thing
and it even got 99.99% of the carbon out of the ports, all i had to do was just scratch the last tiny bits out with a screw driver...
Mike, AKA the sasquatch
Purple power is a high strength degreaser. They sell it at Wal-mart, parts stores, and probably other places too. You can get it in a squirt bottle or a big gallon sized jug. It works wonders, and can be used on everything from cars, to carpet.Originally posted by Hot_Wheels View Postwhat is purple power? ill look for the castrol stuff when i go to wally martThe normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
purple power is basically the same as castrol super clean, both are at walmart, castrols a little more expensive but its not diluted at all if u buy the gallon, not sure about purple power if its diluted or not but castrol works great on anythingOriginally posted by Hot_Wheels View Postwhat is purple power? ill look for the castrol stuff when i go to wally martIt's not the size that counts....It's how you use it.
90 L 5spd- BP project
90 L auto-rusted out and wrecked used as a parts shed
89 LX auto- sold to a friend
89 L 4spd- Gave to cousin as a first car
95 Honda Civic EX
99 Jeep Cherokee SE
07 Mazdaspeed 6 GT
07 GSX-R 600 K7
Just be careful not to get the Super Clean on anything painted that you want to stay shiny. Super Clean can etch painted surfaces. I use it to clean engine bays before painting them because it saves me alot of "scuffing" time with a scotch brite pad
