I can't recall the car forum in which I read this, but someone claimed that reducing one pound of rotating weight (as from the wheel or tire) results in a weight reduction enhancement the equivalent of four times the weight if it were the body of the car (sprung weight).
In other words, if I go from my Aspire wheels (13 lbs. each) to Civic VX wheels (9 lbs. each), that's saving four pounds per corner (assuming the same weight tires here) of rotational weight, for a total weight savings of 16 pounds. This "formula" posits that that rotational weight reduction would be like reducing the weight of the car proper by 4 X 16 pounds = 64 pounds.
Does anyone know if this idea is valid, at least mathmatically on paper? I know that if so, the real world results will often vary a bit, but I would like to see where this comes from and if the source is credible and has some accurate science to it.
All I do know is that reducing the weight of the wheels and tires is a very good, perhaps "best" place to reduce weight, and one of the worst places to add weight.
Thanks,
Karl
Thanks,
Karl
Poverty produces creativity
