Certainly the weight savings in wheels/tires will have an effect on handling and braking, i.e. lighter is better; but a weight savings if 16 lbs is just that. I think that 64 lb number is some sort of equivalency formula, for a straight-line braking situation; but it wouldn't have anything to do with damper rebound. Taking 64 lbs out of the sprung weight, like removing seats, spare tire, etc., won't make the unsprung weight (wheel, tire, hub) work any better.
Rotating weight savings claim...
now wait Tom, you gotta remember that once that weight is moving, it's static equivilant changes. ever see kids in a sience museum sit on a stool and with no other force working on them, are able to spin on said chair by holding a spinning bicycle wheel? same principles apply in a car. so yes it DOES affect damper/spring rates, requires braking force, and cornering grip/turn in/feel.Trees aren't kind to me...
My wheels weigh 38 lbs each with tires
-Greg
Redneck Engineer
FOTY - '09
I will grant you that another 64 lbs of sprung weight will compress the four springs a tiny amount; but other than that you're still dealing with the heavier tire/wheel, which will resist movement in a new direction (up/down, and faster to slower or vice versa) more so than a lighter combo. The wheel/tire weight is much more important than sprung weight, when we are talking about small numbers like this.Originally posted by FestYboy View Postnow wait Tom, you gotta remember that once that weight is moving, it's static equivilant changes. ever see kids in a sience museum sit on a stool and with no other force working on them, are able to spin on said chair by holding a spinning bicycle wheel? same principles apply in a car. so yes it DOES affect damper/spring rates, requires braking force, and cornering grip/turn in/feel.
A stock 12" tire/wheel weighs about 23 lbs. My 14"ers weigh 30 lbs each, for a total difference for four wheels of 28 lbs. I'd much rather reduce wheel weight than sprung weight for better response. 28 extra pounds of rotating mass will take longer to stop than just having a 28-lb toolbox in the car, for example.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Although lighter wheels of course help acceleration, as well as gas mileage from a stop to cruising speed.Originally posted by bhazard View PostThere's a reason Honda used 9lb wheels on the VX, and it wasn't for looks or acceleration.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMOCertainly the weight savings in wheels/tires will have an effect on handling and braking, i.e. lighter is better; but a weight savings if 16 lbs is just that. I think that 64 lb number is some sort of equivalency formula, for a straight-line braking situation; but it wouldn't have anything to do with damper rebound.sry, i didn't specify what was moving... i was refering to the rotating wheels only and in responce to your earlier post as i read it.Originally posted by TominMO View PostI will grant you that another 64 lbs of sprung weight will compress the four springs a tiny amount; but other than that you're still dealing with the heavier tire/wheel, which will resist movement in a new direction (up/down, and faster to slower or vice versa) more so than a lighter combo. The wheel/tire weight is much more important than sprung weight, when we are talking about small numbers like this.
i aggree that reducing unsprung weight is paramount for all aspects of performance and that the claim in the original post is true (to an extent).Last edited by FestYboy; 08-21-2010, 10:18 PM.Trees aren't kind to me...
