I just purchased a little red 88 festiva. I can't find the specs on what the tire pressure should be on the front and back. Can anyone help me out with this?
1988 Festiva Tire pressure?
According to the sticker on my door jam, here's the specs.
For 145/12 (front and rear) 32 psi
For 165/70/R12s (front and rear) 29 psi
FWIW, I run 155/R12s and kind of split the difference, running them at 30 psi.
Can't get either size here, only option for 12" tires is 155/R12s which I generally run at around 30-31 psi.
Copied from this thread. There should be a sticker inside the passenger door frame with this info.
1989 L - 247K miles Slick
Look at the tires. The air pressure is listed on the tire. Run it at pressure listed. I run mine at 35 lbs(a couple pounds over)
Welcome to the site and put your location in your profile. You have just become a member of the best forum on the net!Dan
welcome to the site.... 33-35lbs, look at the tire and use that as a guide."FLTG4LIFE" @FINALLEVEL , "PBH"
^^ 44 psi?? Wonder how much blood you end up peeing out running 44 psi on these roads around here. :shock:
Originally posted by drddan View PostLook at the tires. The air pressure is listed on the tire. Run it at pressure listed. I run mine at 35 lbs(a couple pounds over)
in short, don't follow the numbers on the tire, go with the tag on our car. if you want a little extra milage from a tank, add another 2-3psi and that's it...Trees aren't kind to me...
Originally posted by FestYboy View Postover inflating a tire causes excessive center tread wear, and reduces grip (smaller contact patch).91GL BP/F3A with boost
^it will be more prevailent on wider tires, but it's still an issue with radials.Trees aren't kind to me...
