jc whitney is supposed to have one dont know for sure if it will fit
What's the current scoop on robust trailer hitches?
Originally posted by Oren09 View PostWhat exactly can you haul with a Festy?
Mine has a trailer hitch on it.
I'm thinking of removing it.
I really see no point. I'm also not keen on putting a trailer on such a tiny car because the engine and suspension aren't designed for that.
I have a truck with 7000# rated towing capacity should I need to tow...Originally posted by Bazzy16 View PostI have one of these trailer hitches (not a home made one) and all the wiring for the lights. it was on my car when i got it and i have since removed it. it's just sitting in the shop...... should probably get rid of it haha-Greg
Redneck Engineer
FOTY - '09
Originally posted by Oren09 View PostI really see no point. I'm also not keen on putting a trailer on such a tiny car because the engine and suspension aren't designed for that.
Then then maybe you lend it to AlaskaFestivaGuy so he can get his crate home.
He using what he has, how about sending that hitch to him?'93 Blue 5spd 230K(down for clutch and overall maintanence)
Ah, true. If all you have is a Festy, then you kinda have to use it.
My first vehicle was this truck. There's always been one in the family prior to that. So I'm used to the presence of power/cargo space/towing capacity.
I don't have trailer wiring. The PO had spliced into the rear brake lights for that. I just replaced the lights yesterday and luckily the splices were in the unit harness.
I'll take a look at the hitch later and see how its attached and see if it can be removed.~Austin
Red 88 L (Ocho)
I peeked at the hitch today. Its too cold to do anything, and I'll be working on the front end (control arms, brakes, oil change) soon, so I'll poke at it more then.
It bolts to the spare tire well and to the bumper. Doesn't seem very strong, but I guess it works.~Austin
Red 88 L (Ocho)
I coulda used a tow bar last summer. A friend's 94 Caddy Brougham died and my fasty pulled it about 11 miles home. That was a lotta fun, you shoulda seen the looks we got from the people going by.
