Advice on buying a motor
  • Advice on buying a motor
    Hey all, I'm going out today or tomorrow to look at a motor, what things should I look at to check it? If it were in a car, I'd like to hear it run, or at least check fluids and compression, but this one is pulled already. If anyone has any experience buying used motors, please give with the info!
    John
    91L 5-speed, RIP
    89L 4-speed, teal/white
    http://johnriederer.blogspot.com
    Look in the motors forum at the swap info in the stickies
    92 GL - parts car
    97 aspire - parts car
    87 323 DX - daily driver
      generally look for any signs of cracks or warping and if at all possible open the cam shaft cover to look and see for burn marks or burnt oil. If its clean most things to look for are obvious but if its already pulled its gonna be hard to tell if it has any internal damage. Rotate the crank shaft and have some one look in it to make sure all pistons are moveing and listen for any abnormal noises when cranking it.
      Parker
