I did a search and didn't find any thing relating to this theory. This would probably be more appropriate in the fall. Any way I was cleaning up the stiva and was looking in front of the rear wheels in the dogleg and saw a rubber plug. I pryed it out with a screwdriver and there's a hole that allows access to the inside of the rocker panel. I took a little squirt can and put gear lube in it, and i filled the rockers up with 90w. There are some drain holes it will run out though, if you get a lot inside you may want to park it on grass or gravel or put rags underneath it.
Keep you festy clean and rust free like these..
![Big Grin](https://fordfestiva.com/forums/core/images/smilies//biggrin.gif)
