Rust Prevention Tip
  • Rust Prevention Tip
    I did a search and didn't find any thing relating to this theory. This would probably be more appropriate in the fall. Any way I was cleaning up the stiva and was looking in front of the rear wheels in the dogleg and saw a rubber plug. I pryed it out with a screwdriver and there's a hole that allows access to the inside of the rocker panel. I took a little squirt can and put gear lube in it, and i filled the rockers up with 90w. There are some drain holes it will run out though, if you get a lot inside you may want to park it on grass or gravel or put rags underneath it.
    Keep you festy clean and rust free like these..
    The H.A.M.B.
    http://www.jalopyjournal.com
    The H.A.M.B.
      That might have been a good idea if done early enough. I bought a festiva that must have had a leaking valve cover gasket from the factory and was never changed. It was coated with oil undreneath the car ( worst Id ever seen ) but had no rust down the passenger side of the car. I surprized it never got fire.
        Ya the white one is getting there. The low mile red one has oil down the passenger side of the bottom of the car. Needs a crank seal. It doesn't get driven as a daily though
        The H.A.M.B.
          There was this old guy out in Granville when I was a kid who had a body shop. His standard "rust proofing" treatment was to spray used oil in every nook and cranny he could get to under the car
            Ya I hate rust. It's worth taking your time and doing things like this to avoid it.
            The H.A.M.B.
              This method is as old as the hills, the most effective, and the least accepted by run-o-the-mill refined folks.
              Btw, I question the comment that it is a good method if you get to it early enough; I think it is a good method any time - once you are done with whatever body fix you are going to do. Am I wrong? For example, does it have an adverse effect on finished bondo?
              Little Red Car
