The field coils generate the magnetic field in the alternator, which is used to generate the alternator's output from the armature. When starting, the battery's current is used to energize the field coils.
Once the car is started & running, if you disconnect the battery, the load from the electronics in the car helps sustain a current thru the field coils. This keeps the magnetic field going & the car will continue to run.
I'm told this is a way to check for a good alternator, but also a really good way to burn an alt out.
-Rocketman
-Rocketman
