Dumb question...
  • Dumb question...
    I have an extremely stupid question to ask but im not sure...im doin a swap soon, if I pull the axle shafts when I pull the motor, can I still wheel the car around? Thanks and sorry for the dumb question
    Tyler
    91 Festiva, 5spd, B8 swapped, now for paint and suspension
    you can but I would put bolts with washers through the hub centers so they bearings don't come apart and the car doesn't hit the ground.
    Facebook Me!
      Hubs will separate.
      91GL BP/F3A with boost
        So put a bolt through the bearing with a big washer on each side? Thanks for the super fast response!!!
        Tyler
          Anytime you don't need your old axle for a core charge, keep both axle ends and you can use them (outer piece instead of a bolt) and take the cir clip off the inner one and use that to keep your spider gears from falling into the transmission. If you are planning on pulling both axles out of the transmission and don't have an old stub shaft to put in one side, then use something like a short piece of a broom handle stuck in one side of the transmission in the axle hole. Make sure the stick goes all the way into the spider gear or you could be a very sorry camper.
          You gonna race that thing?
            Hmmm...hopefully that didnt happen with my f-series...its just sittin in my barn waiting
            Tyler
