Originally posted by ideas
Project name: 1/8 Wonder of the World (he is using a 125cc engine in a formerly 1.0L Metro, which is 1/8 the displacement
)Base: 1992 Geo Metro, 3 cyl 1.0L, 5 speed.
Engine: Unknown make and model, 125cc 4 stroke dirt bike motor, 4 speed
Basic Plan: Not sure how he was planning on making everything work exactly, since his job caused him to move away before he got too far on it, but he took everything with him to continue. He was going to keep the 5 speed trans and link the output shaft from the dirt bike trans to the input shaft of the Metro trans via chain drive with gear reduction (probably a couple of sets of chains/gear). The idea was to have it work kind of like a 5 speed semi with a two speed rear end. In effect you would have 20 gears to choose from, so it would be a pain to drive probably but you could have 1st geared low enough that the low HP/torque of the bike motor could get you rolling and start shifting through till you topped it out.
If he had stuck around we probably would have ended up EFIing by building a "mini-squirt" system for it. He and I and another guy John (who IS an electronic tech) built a multiport EFI for a 14 horse B&S V-twin back in highschool. We did most of the mechanical work, and John did the rest of the magic. Never really got much efficiency testing done on it, but it ran just as good as it did with a carb. For inputs he used (I think) engine temp (it was water cooled), some kind of Hall effect sensor for the timing, a VAF that he built (don't ask how lol idk), a TPS that was basically a fully variable potentiometer attached to the TB, and an O2 sensor. We had to "remanufacture" the flywheel and some other parts, put a port on the exhaust for the O2, built an intake from scratch and I don't remember what we go the injectors off of. Probably wasn't too efficient, but it was cool!
