drag truck
  • drag truck
    I have a 87 Mazda b2000 that I got for almost nothing. It had a broken crank.
    I was going to put a Kia four cylinder in it as they share a block, but after I was given a blazer, and watching a lot of pinks all out, I now want to build a purpose built drag truck.
    I see using the duratec v6 3.0 with a big Turbo. Found a Guy making t5 adapter plate, Which should let me use a c4, reverse manual valve body with transbrake. 4 link the rear.
    What ya think?
    Neil
    Jesus loves me. This I know.
    93 L track prep in progress
    88? Parts car-sold
    91 L B6-me f25mr-soon to be ???
    86 b2000- pisses of HOA-sold
    1997 k1500 suburban- kid hauler/GAS hog
    sounds sexy! Kind of like a poor mans GMC Syclone
    1993 Festiva L, aspire swapped, selling parts for a BP+T build.
      why not just stick a 5.0 and a 5 speed in it? or a aod in it....
      Mike, AKA the sasquatch
        Cause 5.0s suck and like to split in half at 400hp.
        And everyone else has them.
        Why would you want to be like 95% of the mustangs out there?
        91GL BP/F3A with boost
          Exactly. And it wouldn't be "Mazda powered" even though the duratec motor is a Ford deal, the mpv, tribute, and some of the mazda6(I think) came with that motor.
          Neil
          88? Parts car-sold
            This is what I'm thinking. It has a Toyota motor, but it is still BAD ANKLES!
            Neil
            88? Parts car-sold
              bro, that is crazy sick...lets do it.
              what about one of these:
              93 Festiva L (B8 swap in progress)
                What??? Good thing to know, because I think we have several people on here well over the 400hp mark with a SBF.
                The aftermarket is loaded with parts. You can put together a 331 or 347 stroker with your choice of aluminum heads for relatively cheap. That being said, I like the idea of a 3.0L Duratec turbo. It would be unique, and the engines are plentiful. The bottom line is that with the RWD truck platform, you can put almost anything in it.
                  Eh, i'm making 362hp at the wheels, that translates to about 417 at the crank. The same engine used to be ran in a 10 second car and launched/shifted at 7400rpm. It's all in how you build'em.
                  By the way, ^^^ That's 99.9% city driving :cool:
                    Ummm....Brian...25horseplay....has a twin turbo 5.0 cobra putting over 500 to the wheels....
                      I know, I've seen the car.
                      450-500 is about the limit for a stock block though.
                        The b2200 is a heavy truck to be starting with.
                          I think its about 2600lbs. Correct me if I'm wrong.
                          Neil
                          88? Parts car-sold
                            turbo SHO engine
                            Rolling into the boost, the tires brake loose at 70mph.
                            Proud owner of Casper
                              find you a 460 / c6 combo ( dirt cheap) Then pick up a cheap stoker kit and take it to 552 CID.
                              Heres a kit for $1300.
                              money pit
                              No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
