Fuel pump died...upgrade difficult?
  • Fuel pump died...upgrade difficult?
    After 244,000 miles the original fuel pump died in my Festy. I must say it was by
    far the easiest fuel pump removal I have ever done!! Why can't all cars be this easy?
    I figure if I'm going to put a new one in it might as well be better a one. I have seen some people have upgraded to a Walbro 255lph. How hard is to do? (I have an old Walbro pump out of my TurboCoupe and it doesn't look like it will swap right in.) Is there a kit? Is there a kit with a smaller pump...don't really think my Festiva will ever make over 500hp even with an engine swap but I would like to have more flow than stock in case an engine swap,
    turbo or something is in the future. Thanks for the help.
    1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
    1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
    I believe you use a pump from a first gen eclipse but don't hold me on that.
      there are LOADS or pumps you can use!!
      I posted them for someone else here: http://www.fordfestiva.com/forums/sh...ight=fuel+pump
      Walth
      Festiva #1: 91 Red L 4/5
      http://www.fordfestiva.com/forums/sh...ad.php?t=27981
