axle shaft questions
  • axle shaft questions
    im looking on ebay at xr2 shafts, the driver side is correct 26 spline inner and 24 spline outer, but the passanger side sais that its 24 spline inner and outer! wtf that dosent make any sense?! i counted the splines for the trans side of the half shaft and it is a 26 spline so is the listing just incorrect? here are the listings im looking at
    passanger side axle
    driver side axle
    88 festiva lx, 2.3 turbo rwd swap in progress
    1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
    R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
    00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
    03' gt, full termi swap 700+ whp build
    sponsered by,
    pam pam's junk, dayton OR.
    Bob's ok tires, salem OR.
    Clausen Truckin', keizer OR.
    are you using the intermediate shaft? the picture looks correct
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
      yes i have the int. shaft and its 26 and 26 spline. so bot axles should bthrough anothere 26 inner and 24 outer, i just dont want to go through another ebay dispute bc someone put a part under the wrong application. its a real pain and time consuming, the pics lookk correct and the size looks about right but the splines raise concern for me.
      sponsered by,
        i would recommend Empi brand shafts, there a big name in vw stuff, i had a set of mc autoparts and there not as good as the empis, the empis are a lot thicker and look much more heavy duty. there not remand's either. i called and i think they where 80 a piece and no core
          It seems to have conflicting info in the auction. At the top, it says XR2 + Base model, and I know for a fact that'd never work in a base model.
          However, at the bottom it shows turbo only.
          I'm going to guess its probably the right part with some bad info. I dont even think there is any application that uses a 24 spline inner?
          Rocketchips!
            well i guess i will just buy them and cross my fingers! and hope for the best!
            sponsered by,
