Painted bumpers
  • Painted bumpers
    Did festivas come stock with painted bumpers? I see a bunch of them from time to time and i was just wondering if people did that on there own or the cars came that way
    Ian Carr
    88' flat black festy, has an e-brake that works!
    99' S70 T5M- faster DD
    86' 951- almost ready for track season
    My old b6t- wish i still had it
    http://www.cardomain.com/ride/2241793
    Every car I have owned has had a turbo in it, until I bought this latest festiva.. I plan to fix that though.
    yes, they did on the GL's (1990-1993)
    i think I've seen them on a select few LX's (1988-1989)
      If you paint yours be sure to use alot of "flex in the paint" other wise the paint will flake and chip right off. I have seen some 88 and 89's with painted bumpers. I you paint your just be sure to add flex in the paint.
        Both my 91GL's have factory painted bumpers. My 90L does not
        Paul
        91GL
        Menomonee Falls, WI
          besides the flex additive
          prep is the most important thing to do before painting
          sanding and using a high quality prep solvent is a must
          then using a bare plastic adhesion promoter also a good idea.
          then use a good sand-able primer , to fix imperfections or maybe to cover the texture of the unpainted bumper.flex additive can be mixed into the primer( with some primers only)
          then wet sand and clean with prep solvent
          then use a compatible sealer before your base coat(no flex here)
          apply basecoat
          then apply clearcoat mixing with flex additive
          if not using a two or three stage paint(base+clear or base, mid-coat + clear)
          and decide on using a single stage (no clearcoat used) you must mix it with flex additive.
            I think i might just stick with the race Grey plastic bumper. Plus paint will weigh the car down :twisted:
            Ian Carr
              weight it down??????????????
              at between 2 and 3mm for total coat depth............
              YEAH RIGHT!!!!!!!!!!
                psh those 3 coats of paint must weigh close to 50 lbs! thats over 50 hp added if i dont put them on!
                Ian Carr
                  50 pounds :shock: only if your using a led based paint that is a 50lb brick of lead in a can of paint. If you are just painting your bumpers your looking at more like under 1 pound of added weight. Plus you will end up with less wind resistance with the gloss paint (minimal but every little bit helps). :twisted:
                  Festiva/Mazda genetic splicing researcher B6T / G25MR for 5+ years and counting.
                  187.7 WHP @ 5500 RPM
                    psh 1 lb, 50 lbs close enough
                    (sarcasm for any one who thinks I'm serious that paint weighs 50 lbs)
                    Ian Carr
                      next time I'll weigh it before i paint it.
                      my guess about a 1/2 pound.
                      most of the solvents in the paint and clear evaporate while it dries.
                      and if you need to lose weight, just look at the fat ass behind the wheel, can we say DIET?????
                        ouch... lol
                        I guess i know what i need to start doing ops: :pukeright: :puke:
                        Ian Carr
                          The painted bumper was an option. I have a 92 GL the really bright sea breeze blue and it has them. I asked this question about a year ago, and someone posted the paint codes by year and model! It was awesome. Great info if someone had that available to post again.
                          I can't imagine paying extra for a "Painted Bumper" option. LOL. I do think the painted bumpers look better, plus they don't fade like the gray ones do.
                          Rob "BossMan" Petty
                            My 89 has black/grey bumpers. I plan on either painting or replacing them because I personally do not like the black ones.
                            93 GL modyfied!!!
                            :fish:
