Nuts and Bolts! Need Help
  • #16
    can you get a selection of T bolt clamps, some of the guys might like them for a dress up feature
    • #17
      Yes sir I can
      My Musica! Click me!
      • #18
        Originally posted by Charlie1717 View Post
        But the 10.9 (or grade 8 ) will definitely be necessary for the higher stress stuff like suspension, but will be zinc plated so will still be decently protected.
        Or you can use AuVeCo to get the ones with the correct coating. They sell to Fastenal, but not the general public. I think they only sell box-quantity as well.
        BTW, most off-the-shelf bolts & nuts aren't supposed to be used on suspension. The bolts may be the same grade, but there is more to suspension bolts than the grade. They have special threads (forgot the name for them) & the nuts are usually (non-nylon) locknuts, which are purposely distorted (to prevent backing out completely by being "tight" the whole way)....just pointing out some of the issues, since liability should be a concern.
        But again, AuVeCo has the correct stuff for automobiles & they supply Fastenal.
