So i bought a delayed wiper set up off Gomez, installed it and waited in full hopes that it worked( not as in i didn't think it was a good part). Is it the norm for the intermittent to only stop for a micro second? It is the fastest delayed wiper ive ever seen. Did i do something wrong in the install? Is there a way to slow it down more?
delayed wiper info
What's it off of? Is it adjustable delay or one-speed delay?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
OK, it's a one-speed. That should go off about every six seconds.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Donnie, measure the time between swipes and let us know. Just estimate based upon "one-thousand-one, one-thousand-two," etc. if you don't have a timer.
"Microsecond" sounds to me like a continuous wiper mode.
The module must be screwy. Try replacing it.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
