hay guys if my light/turn signal switch is broke as in i hit and herd a pop could that cause my car not to start
Broken/turn signal switch
Highly doubt it1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
that pop could have been a fuse, but i'm with mcnasty, the likelyhood of it not starting because of the combo switch is very low.Trees aren't kind to me...
Have you checked your inertia switch?1992 white L, Bp, American racing 13's, stock trans.
ok guys i have done everything i can think of im lost at this point i know that the little brown box on the fender wall where the links go some times rust or get dirty i have cleaned the im about to take that apart and make my own links to go in there i have replaced the rotor button the cap the coil the icm and still nothing no spark if there is something im missing plz help i get fuel but no spark i need help bad
Bad ECU possibly?89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
check the position of the rotor....if it is like the B3 one it can go on in 3 different positions.
Also maybe you have a dead short until you let off the key when trying to start it."FLTG4LIFE" @FINALLEVEL , "PBH"
