My festy has been running kinda rough on idle at stops and even once turned off, any suggestions? It has also had a little trouble starting (it will try aka the battery isnt dead but it wont turn over) My dad said to try cleaning the flue injectors via gas supplement, went to o'reilly's and they gave me the best stuff they had, but havn't seen any great improvement (granted I only drove it home and I don't know how long it takes to work) but I was wondering if you guys had any other ideas! thanks.
Rough engine idle
that stuff won't work within a few miles, it's designed to work over several tanks.
what do the plugs/wires/cap/rotor look like? clogged air filter? newer fuel filter?Trees aren't kind to me...
i don't know of any mechanic that can see the inside of filters without cutting them open... just sayin'. but i would start with the basics for sure. post picks too !!!Trees aren't kind to me...
inspect your ignition system anyway, it may be due for new stuff.Trees aren't kind to me...
