My car had a wire there, my other car.has discoloured insulation, Rebecca's car had a wire that was burnt up there.
What causes the fusible links to go bad? particularly the center 40A?
2015 F150 SCrew - DDTags: None
Ford had published a TSB about this in '89. The center link was actually a 30A, Ford changed the rating to 35A, due to premature, unwarrented failures. I run a 40A cartridge in all of mine. I did some current flow calculations on the main harness wire gage, and it can safely handle the 40A cart.Jim DeAngelis
Been running 40A (green) in mine for 10+ yrs in two cars currently on the road.
Only time I had an issue was when I left the lights on and the battery was calling for all the current it could get, 40+ amps, and it failed, as it should.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I also have a 40A cartridge fuse in my festiva, no issues at all
Only time I ever blew the fuse was when my alternator was over chargingLast edited by Damkid; 07-21-2011, 03:32 PM.
