Miata Lowering Springs?
Do it"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Lane wrote:
"I'd say early miata would be the way to go.....Here's some stuff I found though."
Agreed. Some work would need to be done on the rear to raise the spring perch. Perhaps with a combination of a Honda lowering kit and fabbing up a new spring perch to fit the Miata spring would work.
Shouldn't be too difficult and the spring rates seem appropriate. According to the last link, 235# front and 173# rear for the Tien lowering springs, if I read it right. I wonder what regular Miata springs would do? There should be spring offerings from other vendors as well.
I'd run front Miata (lowering?) springs on Rio struts.
KarlLast edited by Safety Guy; 07-22-2011, 08:02 AM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
Ask and ye shall receive, Karl:Originally posted by Safety Guy View PostLane wrote:
Karl
1990-1993 (NA) MT - 164.17/96.94
1990-1993 (NA) AT - 153.52/93.53
Mind you this is before any sort of cutting or heating to modify them and permit lowering. Source and detailed information including all of the measurements you could ever want:
As for raising the spring up:
Don't bother paying for a coilover kit... waste of money when all you need is some threaded aluminum sleeve and a spinable perch material. This'll have to be bigger than standard 2" though for Miata parts to work. 3.27" is roughly 82-83mm I'd guess, so find some aluminum threaded stuff and some durable perches and go to town!
http://www.fordfestiva.com/forums/showthread.php?t=184 is particularly relevant. Gives you a great visual on how you can get sleeves on there covertly too!
As it would seem, finding threaded 3" pipe and tubing is practically impossible unless you only want the end of it threaded. It may be wiser to just use regular pipe and have a custom perch welded on. Measure twice, cut once I suppose. Start high and sort of sawzall your way down to a comfortable and well-performing ride height. Was worth a try though - either way, it'll be easy to get this working for those who want to use Miata lowering springs in lieu of coilovers.1988 Chevy Sprint Turbo 997cc
