Drained of brake fluid before damage occurs? I heard there's a diaphram inside that will rot out or something?
how long can a master cylinder stay dry
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
"If it moves, grease it, if it don't, paint it, and if it ain't broke don't fix it!"Tags: None
i had a leak in one of my brake lines and all the fluid drained out, so I had to replace the rear brake line, and went ahead and fixed the rust spot on the other rear brake line while i was at it, it's been 2 weeks, and the fluid pretty much drained out of the resovior.. is there gonna be an issue?2008 Kia Rio- new beater
The important thing to remember is that brake fluid by design absorbs water, so is the system is left open and any fluid is exposed to the elements, it needs flushed and replaced.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
naw the cap has been on it and it didn't sit for long before i fixed the leak.. i'm just hoping that it'll be ok, i'm gonna ATTEMPT to fill and bleed the brakes tomorrow. i hate bleeding brakes.. i had a bleeder valve snap off of a caliper on a 85 ford f250 i had, eh 3 outta 4 aint bad tho right?2008 Kia Rio- new beater
