Going to look at an escort gt on Friday! 164,000 miles new water pump, timing belt, injectors originally posted for 500 he told me he would let it go for 400 so I'm going to offer 350. So excited
picking up an escort gt!
JUMP on IT !!!
What year? Reason I ask is because of the crank snout size.-Greg
Redneck Engineer
FOTY - '09
Good news is that if it was an SNC and they didn't remove the crank bolt when they did the TB (you don't have to on an SNC), you shouldn't have and trouble (most likely). However, if they did remove it, or if its a BNC (requires you to remove the bolt) then I might be a little wary of it. Still, great cars!No festiva for me ATM...
Its a 92, heres the link http://milwaukee.craigslist.org/cto/2499070085.html:cry_smile: RIP. 91 Ford festiva BP swap
1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
Drive it. Then buy it if she runs good.-Greg
Redneck Engineer
FOTY - '09
Originally posted by eurotiva View PostJUMP on IT !!!Only two opinions so far, but they seem to be in agreement with one another. Only thing I would seriously recommend is going ahead and ordering and installing a new crank bolt and key just in case someone botched the torquing of the bolt or fitment of the key during the timing job. If you put it in then at least you know if it was done right or not.Originally posted by htchbckStill, great cars!No festiva for me ATM...
yours is a 92, so you're good..
here is the issue: http://miata.net/garage/crankshaft.html
-Aspire brake swap COMPLETE!
Just because its a '92 doesn't mean its not the SNC, in fact I believe that I read somewhere the EGTs had SNC through '93. But that is neither here nor there. Bottom line is if you have any reason to believe that the timing belt job could have been sketchy, I wouldn't take any chances. My '92 Miata (late '92, BNC) apparently had a shattered crank key at some point, and the last shop to mess with it had cut a bigger channel on the timing cog and welded half the old key to half of a newer bigger key. Needless to say that didn't work. I replaced it with a used timing cog (un-molested) and with a new key and crank bolt it seems to be holding up ok.No festiva for me ATM...
picked it up for $385 runs great, fresh oil change with synthetic... Do i keep running synthetic? motors coming out tomorrow. Ill post pictures toomorrow as well. rear strut tower was gone.:cry_smile: RIP. 91 Ford festiva BP swap
