Festiva wiring through cassette player ... is essential to the starter?!
  • Festiva wiring through cassette player ... is essential to the starter?!
    So i went to remove that old cassette player that's been hanging out of the dash ever since i bought this awesome Festiva from my sister for a song. I snip all the wires and out comes the stereo, which i toss. Then i go to start the car and there is no juice to anywhere! It's dead as a log. What did i snip wrong? How might i get my fun Festiva to start again?!
    >Marlin
    did you cut the wire harness?
    Proud owner of Casper
      >Marlin
      Check your fusible links under the hood, sounds like you might have shorted one out (MAIN) when you clipped the wires. If that's the case, do a search for cassette fuses at your local auto shops. The part number I use up here is FTF-40 for a 40amp fuse, but the part number there may be different.
      Btw, I'm looking for a stock Festy radio if you're looking to have someone use it instead of tossing it, (it and its radio plug). I park my Festy in a surface lot all day, and having a stock radio in Farmstiva won't be any different to a thief than having the hole in the dash that I currently have (and no way to hook up a stock radio), but would make a world of difference to me driving back and forth from the city every day (roughly 55 miles/90 klicks one way).
      Carz:
      '09 Ford F-150
      '80 Chrysler LeBaron Town and Country
      '80 Volvo 240 2dr coupe
      '93 Festiva GL
      225996.9 kilometers = 140428.0 miles on the odometer
      ...and definitely more soon..
        I got this. PM comming your way.
          @hamburglar : Can you provide a bit of info about how i might identify "the wire harness"?
          @darrenyall : I will: Check your fusible links under the hood, sounds like you might have shorted one out (MAIN) when you clipped the wires. If that's the case, do a search for cassette fuses at your local auto shops. The part number I use up here is FTF-40 for a 40amp fuse, but the part number there may be different. Also, i will take a picture of the cassette player and you can see if you want it, if i can find it. (Maybe i didn't toss it *out*).
            Just checking in.. was the fusible link burnt out?
            Carz:
            '09 Ford F-150
            '93 Festiva GL
