There is a guy here that has wheels for a Mazda miata that are 14 inch tires and a 4x100 log pattern . Will these fit on my festiva with no modification? He's gotta sell them quick so of someone can help me with a answer that would be great .thanks
HELP!!!! wheel size
You are correct. They will fit only with the Aspire swapOriginally posted by Brayy View PostOnly if you have done the Aspire swap from what ive read.. other than that i dont think so. Correct me if im wrong.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
the stock festiva bolt pattern is 4x114.3 im not sure of the offset though. when you do the "aspire" swap (taking the suspension system from a late 90's ford aspire and putting it on your festy) You will now have a bolt pattern of 4x100. Again i dont know the offset numbers but the aspire swap does two big things.
Gives you a better, larger selection of wheels.
Improves your braking and stability.
also lets face it, 12" tires are pretty much obsolete. upgrading wheel size may be a wise choice
my .02
