Don't know what the real problem was but when I would start the car it would run for awhile and then it would stutter a little and then it would just stop. I checked and I do have spark to the distributor. I even too distributor cap off and cleaned all the little tabs and the rotor. I thought it might be fuel filter(which is pain to change) and it did it after that. Then the next day I started it, it did it again. I waited for short time, tried it again and it started. This time check engine light came on. I turned car off, restarted it and light didn't come on anymore. I went up to parts store and got an o2 sensor and put it on. Started car and it is running pretty good now. I even cleaned battery posts and made sure ground wire was tight. I do have question. If I were to leave the regular fuel filter on, and put a see thru filter between it and throttle body, would it hurt the gas pressure any. That way I could see if it happens again, am I having any trouble with fuel pump. Maybe its going out or the little screen on it is getting plugged up. The reason I'm thinking fuel is it is acting like my truck was doing and after awhile it just would not start so I changed the fuel filter and was going to change pump and it turned out filter was so clogged. So, would see thru filter hurt anything?
Car would die
most see-throughs are for low pressure applications (less than 6 psi), i'm not aware of an EFI filter that is see-through.Trees aren't kind to me...
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
Originally posted by FestYboy View Postmost see-throughs are for low pressure applications (less than 6 psi), i'm not aware of an EFI filter that is see-through."FLTG4LIFE" @FINALLEVEL , "PBH"
TY for feedback. Do I have to take the original flter off though. I just put a brand new one on, can I run a see thru with it stll inline. Like said, reason for see thru is to tell me whether or not pump is failing. By the way, I will be gone for short. My wifes father passed away yesterday and we are headed for Fort Wort, TX
there should be no issue putting it in line. My other filter was shot and I by-passed it but if your is good and you just want to monitor the flow....there should be no issue.
Sorry for your loss."FLTG4LIFE" @FINALLEVEL , "PBH"
Just to let everyone know what the results have been since I did all the work in the first post to the car. I even put in a see thru fuel filter and the car has been running great since. Been driving it back and forth to work for two weeks and haven't had a bit of trouble with it quitting. Thank you all for your inputs and ty Genevadirt for info on see thru. I used a fram G-12.
