Flyin Miata crank nose tool?
  • Flyin Miata crank nose tool?
    Check this out and someone tell me if it would be useful for any of our engines:
    My guess is "yes." Who can verify or deny?
    Oh, another product, louvers for the hood:
    What do you think? I know some folks were talking about this a while back and maybe this part would fit Festivas better since it's small sized?
    Karl
    I would say yes very valuable for holding the crank when removing the crank bolt for doing a timing belt change. and it will work with a small or large nose crank!
    Facebook Me!
      That's what I thought.
      Now check out the louvers. Yum. (Though maybe some hardware store has some home vent louvers that would work. Ha.)
      Karl
        rocketman is making them!! buy from him alot cheaper!
          I thought the bolts are recessed in the crank pulley. How does the flat tool bolt up? Rocketmans tool is bent to fit into the crank pulley. I would like to know because I need a tool to hold the crank so I can remove the crank bolt from a large snout crank at the salvage yard.
            There is indeed an offset between the crank pulley and the oil pan lip, at least on the B6T...I think on the BP too. My tool matches these offsets so there is no interference & can be attatched from any angle. Not sure if the FlyinMiata tool is capable of that.
            I have versions for both shortnose/longnose (smallnose? / largenose?) cranks presently
            -Rocket
            1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
            Rocketchips!
            Bolt-on Weber Carb Adapters!
              "Will drastically reduce profanity usage during a timing belt change." heheh
              I'm loving those hood louvers.
