Originally posted by Larry Hampton
fails, CNG does not extend the life of gaskets or bearing wear caused
every time you start an engine. Anytime the motor moves there is wear
at all metal to metal surfaces until oil arrives. CNG as a gas provides no
cooling to the valves as liquid fuel does. Engines not designed to shed
the extra heat will suffer as described. Now back to the bull..what did
lead do in gasoline ? The current gasoline additives are not added to gaseous
fuels.
California Bi-fuel ford contours are available free to cheap because of top
end failure and automatic transmission failure. They have all you need to convert a festiva. That little word "convert" is an education.....
