Antenna deletes!
  • Antenna deletes!
    25Horseplay sent me an antenna delete plate a long while back, so I could cast them
    Here's the prototype I made, I still need to drill it out & maybe polish it a bit more. Is anyone interested in these?
    -Rocket
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
    looks good. You should maybe see about getting them made in carbon fiber too. for looks.
    :cry_smile: RIP. 91 Ford festiva BP swap
    1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
      Is that aluminum? Nice job. Looks a litlle longer than the original though, or is that an optical illusion?
      Dan
        It's a chip off the old block
          It's an optical illusion, methinks. It's a little thicker than the original, but exactly the same length. But yeah, I cast it in aluminum
          About the carbon fiber, I could probably do that...I have some resin laying around, but no more raw fiber :/
          Rocketchips!
            That would look nicer then stock if you just glued it on with some RTV adhesive!
            93 GL modyfied!!!
            :fish:
              Wouldnt you have to vaacum it and then put a clear over it?
                I'd probably make a negative mold from it, then resin/vacuum bag it
                Rocketchips!
                  rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrocketma nnnnnnnnnnnnnnnnnnnnnnnnnnnn
                  91GL BP/F3A with boost
                    But if I delete my antanne how will I get radio reception?!
                    2008 Kia Rio- new beater
                    1993 Festiva- Fiona, DD
                    1997 Aspire- Babyspire, DD
                    1994 Aspire - Project Kiazord
                    1994 Aspire- Crustyspire, RIP
                      You guys had the radio option? Lucky
                        Yank an aerial from a newer model car & run it to the rear!
                        Or get one of these!
                        Or a US version
                          They have stuff like this, too: http://www.ebay.com/itm/Universal-Hi...item4842996cd7
                          Rocketchips!
                            My antenna used to be here..
                            Cut thin steel to fit, tacked on, grinded flat, filled then painted.
                            60% of the time it works, every time!
                              New antenna now here, re-outed wiring to h/u.
