My 91 auto has a reving problem. When driving and you put your foot to accelerate even just a little it revs like crazzzzy but will also work just fine sometimes as well. Would that be the TPS?
Thx
1991 Auto Ford Festiva " Noel " <-- cuz theres No L in Festiva
1991 Manual Ford Festiva
1999 ford f-250 5.4L My gas guzzler.
Is it loose linkage under the hood at the transmission? Had a problem with mine not fully engaging in drive and sometimes slipping into neutral . Try bumping the shifter rearward (towards low gear) next time itTuesday happens and see if that works. May be a worn bushing. Let me know if this works and I can post a pic of my temp fix until I locate a bushing
