So the water pump finally died on me..the car is at my brother in laws, and I bought a new pump/gasket/rtv sealant, and a new timing belt, got the plugs out/valve cover off/upper timing belt cover off, and I'm stuck..the crankshaft pulley is kicking my butt, how do I get this thing off?
The book isn't much help at this point, it just says to remove the pulley. -.- i marked the camshaft sprockets and got the car on a jackstand, thanks to the zulu ministries for making that possible, and put a jack under the motor and got the motor mount off. The car is automatic and in park, but the crank pulley spins freely. Sum1 help please!
Probably won't get yourself hurt since you'll be in the car when you hit the key, but if its done improperly it can bang the car up pretty good.
