Ok just started driving my festiva and filled up and only got 260 miles on one tank going to huntville and back soild driving no lights 60 mph what's wrong wit it all the people get around 45
89 carbed only 26 mpg???!!?!?!
there is no way to use 10 gallons in a festiva tank without modification. best I've ever done was 8.66 and I ran it out of gas... even with that I was getting 26-28 with my 89L There are issues with the engine though...89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
?? When is the last time it was tuned, feedback carb checked, wheel bearings,brakes and tires checked, is it auto, what oil and lubes are being used, roof rack and topper?
Clear gas or the gov mandated stuff. Was it just you or did you pack it full lead shot for a gunshow in huntsville ?
see, there's the problem, someone touched the carb.... they're never right afterward. and if the carb IS right, it's periferals are not working, like the ABC valve which controls the a/f ratio, and it can only do it's job if the o2 sensor is working as well as the ECU.Trees aren't kind to me...
Exactly. That is the only way to get an accurate calculation. I don't know how the pick up is on the carb Festivas but when mine starts bucking and sputtering, I put in about 8.5 gallons. When I took the fuel pump out, I didn't notice any baffling, so that may be a reason you can't use all 10 gallons. So just guessing you may be getting closer to low 30's. Have you checked your speedo with a GPS? With the 12" tires mine was reading slower than I was going which would, contribute to a slightly lower mpg calculation. I literally floor mine leaving every traffic light and I get 40 mpg most of the time.Originally posted by 25Horseplay View PostEven if you ran it out you still won't know an accurate reading without filling it back up to see just how many gallons you truly used.Last edited by Eaglefreek; 12-27-2011, 10:51 PM.Rick
1993 Ford Festiva
1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
2000 Ford E350
Originally posted by FestYboy View Postsee, there's the problem, someone touched the carb.... they're never right afterward. and if the carb IS right, it's periferals are not working, like the ABC valve which controls the a/f ratio, and it can only do it's job if the o2 sensor is working as well as the ECU.
Ha we didn't even get to the part about restricted cat and cam timing
Good thing these are such simple cars..
It looks like you are down to rolling resistance or fuel controls messed up. Maybe both to get that low.It should start fouling plugs if its all fuel. Hopefully if you drive it more it will prove out to be math, keep a log on it for awhile.Reflex paint by Langeman...Lifted...Tow Rig
I have filled mine to over 10 gallons several times.Originally posted by Nerd Racing View Postthere is no way to use 10 gallons in a festiva tank without modification. best I've ever done was 8.66 and I ran it out of gas... even with that I was getting 26-28 with my 89L There are issues with the engine though...
Of course, I fill my to the top of the fill tub every time for MPG purposes
1992 Ford Service Manual on back cover under refill capacity says 10 gallons.Originally posted by JoDan View PostYea I was pretty sure they had a 8-8.5 gallon tank.
Though I beleive the Haynes manual references 9.9 gallons.'93 Blue 5spd 230K(down for clutch and overall maintanence)
