I'm not too often bothered here in Bellingham on the north end of Puget Sound on the waterfront; but, enough so that this problem has me again having to admit, as per usual procrastination, goofing off and doing nothing, embarrasses me for the government ward and dependent I've greatly become in some ways.
What happens is whenever the temperature drops enough below freezing, there is no way to get the doors open on the beloved '91 Festiva L. The rubber gaskets around the doors get frozen stuck, so I just wait for the temperature to raise up enough they will release. If there were an emergency the first thing I'd try would be hot water; though then if really cold that would be refreeze soon, maybe with me inside!
I've been imagining that this must be a common enough problem, so that long ago folks have figured out various ways to keep this from occurring. Before I start to experiment, I thought I'd ask to see if anyone has a good method and/ or methods to keep ahead of this? Or, if one is thus confronted and really needs to drive no matter what; how to manage to unstick a door without too much difficulty during or after?
I've been guessing there should be an all-around "perfect" procedure, right? Something I can apply to the gasket surface, both preventing that from sticking to the painted metal surface which the gasket rests upon; as well as being a product neither harmful nor too messy either...also inexpensive and/or even readily obtainable I might already have on hand.
Or perhaps a good cleaning might suffice? I keep around a pint of namptha which works great for lots of things since no oily residue is left, while also drying fairly quickly with a good solvent action...the same thing as lighter fluid, I've recently discovered.
If I hunted around, I'm even pretty sure I'd find some Armor-All stuff which is supposed to be used on rubber or vinyl; though a pretty big project around here, meaning I'll have to start pulling boxes off of shelves, I'd have to access in the first place by standing on a kitchen chair. I'll probably get those boxes out since they've not been looked through in over a year or maybe two; once this is posted, to get a good idea of what I've got to chose from.
Asking first seems a little wiser; just in case I might find for instance, that the same peanut oil I use to make popcorn with could be effective? Plus, I always like saving those speciality stashes like the Armor-All which is a free sample, for the proverbial rainy day; as if I were T. H. Lawrence setting out to cross the Empty Quarter.
I also have a good assortment of various oil based type lubricants; so imagine putting one of those on a piece of tissue paper, could be good to run over the surface of the rubber door gasket?
The best thing would be something which would last awhile after a treatment; like good dentistry, as opposed to what the government limited a person to in Washington state until recently when they ran out of money for even second rate care...reasoning like the right-wing reactionary bureaucracy this place is, if I can budget to buy decent care I shouldn't be getting assistance.
Which reminds me now, of the wiper blades; and my curiosity as to whether or not they can be treated or cleaned to renew them somewhat? The last pair I got are special ones made aerodynamically to keep from chattering or lifting off as the car goes faster, which I've often had some problems with above about 55 mph.
They weren't cheap, so making them last a long time is worthwhile; and I think that they may seem to've deteriorated worse than they actually have, from sitting without much use often times.
I drove to Portland, OR from here near the Canadian border on December 18th, and by the time I'd gotten back after driving south from here to below Salem, OR December 10th also; the wipers finally seem to be working a lot better than at first. Over twelve hundred miles since December 11th to the 19th; sort of the patterns I have often, of feast or famine.
I've even thought of sanding material from the blade surface which touches the windshield; which should give a like new condition if the material is consistent and only the surface areas age rapidly.
