Thank you everyone for helping me in my boost at 5k thread. I fixed the wastegate, took off the hose from the wastegate, welded the turbo manifold, put on the stock bov and that did nothing.
I started pulling plugs and when I pulled #2 nothing happened. I borrowed a compression tester and it measured 40 psi. It's a gonner:cry_smile:
So I think i'm going to try to get a N/A block or just another b6t. What is required to do the N/A block? Is it plug and play?
Would you recommend it against the b6t?
