Hello again,
I am wanting to do my Apsire Front Brake conversion this week, I have a diffrent spec festiva to most of you due to the rims allready being 13" from factory (Australia Spec) Infact they are Aspire rim's but with a 114.3 stud pattern not 100.
NOW....... My question is..... If i just want to add the larger Caliper's and Rotor's from the aspire, can i still use my original hub/stud pattern 114.3???? Or will this not work???
The reason WHY is my rim's will clear the brake's allready due to the 13" wheel's (114.3) and there is no need to do a full conversion (Correct me if i am wrong) because i still want my original wheel's on with just the front rotor's+caliper's.
In this case AND if it will work, Besides the Caliper's and Rotor's what other part's would i need? I have allready seen thread's on the Aspire brake's but my situation is slightly diff.........Please help me
