What doya think of this tire gauge?
  • What doya think of this tire gauge?
    I want to pick up a good tire pressure gauge at Summit and I think this was the cheapest one to mention a calibrated 2 percent accuracy rate:
    Free Shipping - Moroso Tire Pressure Gauges with qualifying orders of $109. Shop Tire Pressure Gauges and Inflators at Summit Racing.
    I want an accurate one! Saves shipping, too.
    Thoughts?
    its analog. You want accurate, go digital.
    Jim DeAngelis
    kittens give Morbo gas!!
      Digital? Really? Adding a battery and some numbers makes that much difference?
      Or is there some type of electronic strain gauge at work there Jim?
      How about just going with the Summit Racing gauge?:
      Free Shipping - Summit Racing SUM-900127 with qualifying orders of $109. Shop Tire Pressure Gauges and Inflators at Summit Racing.
      It says plus or minus one percent accuracy.
        I'd go with that. Analog relys on your viewing angle, as much as the bourdon tube inside is sensitive to humidity and temperature. Too many variables. At 40psi, 2% is +/- 0.8psi. Not much, but not as accurate as +/- 0.5psi of the digital, and more repeatable. I was a skeptic of digital pressure gages myself, but after buying one and using it often, it really is more accurate.
        Oh, and most digital pressure gages use a piezo-resistive sensor, which is basically a strain gage.
        Jim DeAngelis
          The digital one is much more accurate because it uses a pressure
          transducer instead of an Bordone tube, and temperature compensates
          each use, though I personally can't get used to them.
          On the race team we use these: http://www.summitracing.com/parts/LNG-50407/?rtype=10
          as we don't want a battery failure at a critical time
          Just don't mix up the gauges between team cars, they are not calibrated
          exactly the same!!!!
          No car too fast !
            FB71 you beat me to it (typing challenged)
            No car too fast !
              Thanks Dragon!
              Jim wrote:
              "piezo-resistive sensor"
              Ah, yes, I had forgotten that term. Same thing the ammo companies use to measure chamber pressures these days. In the old days they used purely mechanical measures such as how much a copper or lead nugget was squished through a small hole in the actual chamber, thus "copper units of pressure" (cup) or "lead units of pressure" (lup).
              "Home ballistics labs" are now sold which use the piezoelectric strain guages which can be glued to the firearm's outer breech area. The small changes in metal expansion is thus measured.
              Thanks,
                $40? and you have to buy/replace batteries?
                I have one of these (model S60X) in every Festy -- $6.99 at Sears.
                Absolutely the best tire gauge I've ever owned (despite the fact that it says "Made in China").
                88L black, dailydriver
                88LX silver a/c, dailydriver
                4 88/89 disassembled
                91L green
                91GL aqua pwrsteer
                92GL red a/c reardmg
                1952 Cessna170B floatplane
