I am wondering if anybody has adjusted on their clutch and brake pedals heights?
If so, how do you like them? To the factory specs, or custom setting?
Haynes has the clutch pedal height at 8.2 to 8.4 inch, with .35 to.56 inch freeplay.
The brake pedal height at 8.03 to 8.23, with .16 to .28 inch freeplay.
I do not like these settings! My clutch pedal was about 8.75 high, so I adjusted it to spec, still didnt like it (too high) so I re-adjusted to about 7.75.
Much better, but then I measured the brake pedal and it was at about 6.75. So it is not right either.
Mostly I have a problem with the small clutch freeplay dimension. I like the clutch to engage much closer to the floor then the factory specs, giving almost 1 1/2-2 inches of freeplay.
With the factory specs it is like I am holding my leg up in the air to shift, and it seems forever to engage the clutch when releasing the pedal.
What have you guys done with your pedal heights?
lol
