does anybody know where i can get a ignition module that has the numbers J927 and under that it has 0925 this is for the 1.3 mazda. this is the festive made in korea thanks for your help GERALD
1992 festiva ignition module
post a wtb in the for sale forum....junk yard....auto parts store."FLTG4LIFE" @FINALLEVEL , "PBH"
you can find the unit you're looking for from any early 90s Bseries engined car, they're all the same. the junk yard is your friend.Trees aren't kind to me...
The beauty of playing with a Mazda-derived engine is what FestYboy says is correct (but take that part with you when you go looking). The numbers on the unit may not jive that that doesn't mean it isn't compatible. For example I grabbed a perfectly good distributor (for an EFI B3) off a 92 MX3 16 valve B6 last spring.Originally posted by FestYboy View Postyou can find the unit you're looking for from any early 90s Bseries engined car, they're all the same. the junk yard is your friend.
