Festiva vs. Aspire transmission
  • #16
    So the festy 4 speed and aspire five speed ( that I said above ) don't have the same final drive . I clearly said festy five speed was different ?
    New build on the way .
    • #17
      Wasn't this for a Manuel transmission ?
      • #18
        festy 4spd and 5spd are the SAME save for the extra gear. aspire 5spd changes the final but NOT any of the selected gears.
        • #19
          It looks like the lock up converter is no longer being offered ?
          • #20
            Arty; no, the 4spd has a slightly higher final drive than the 5spd, according to my literature. But that may only hold true for the early cars.
            Brad; I'd trust the lockup up to about 200hp. Otherwise, use a Festy converter.
            Jim DeAngelis
            • #21
              Okay !! I was thinking the four speed festy and the aspire were the same ratio . But anyway you can tell the difference between the ratio of a four speed festy versus the five speed festy trans . We built the b6d car with a four speed and after a year we lost forth gear , so we replaced with a five speed and it killed the car on a hill !!!! Now were back to the four speed racecar !!
              • #22
                yeah Jim i've seen both numbers and from what i have in the 89 FSM, they are the same final drive. i don't have the '88 FSM but i do have the trans supliment and it also reads with the '89 FSM as well... i wonder how many early 4 spds were actually put on the road (VIN spread)?
