Went to the local PAP and found the following for soon to do mods as soon as the weather cooperates:
919 Prelude seats, dark blue and match the 93 blue exterior nicely! Pair of Nissan Maxima power mirrors, I believe they were off a 91-94? They seemed to be a pretty close size to the Festy mirror mounts. Will require some modding to the sheet metal of the triangle where our mirrors go. Will leave them "manual" for the time being. My 93 L doesn't even have a right side mirror and those are like hen's teeth around this area. Couple of clock modules and looking to see which one will be a fit into the dash. Found one from the same 91 Prelude I got the the seats out of and looks to be pretty close. Will require some cutting of the dash mount where the stock clock would go. Can't find any 323 clocks.
What mirrors have others swapped out with the Festiva mirrors? Did Ford offer power mirrors on the Festiva? Anyone do a power mirror install? What did you really need in order to do the install? I looked at the switch for the Maxima, way too many wires and connections to be just a simple plug and play set up. Any links or write ups are always helpful
