EGO Problem
  • EGO Problem
    I' have an EGO problem. While flushing my cooling system with dishwasher soap, I had it up on stands running @~ 2200 for a an hour, MIL came on, pulled code 15. I have an EGO problem. back probed the connector -.85V. I'm guessing it is a result of a recent head job that led to an antifreeze contamination. Either way I'm buying a new O2. Anybody out there ever successfully clean an ego? Like spray it w/ brake clean then bake in the oven @ 400 for an hour ... anything? Yeah I thought not. Zirconimum Dioxide must be pretty delicate stuff. Where can I find the part number for my '93?
    '88 LX (VIN#30) one of the first Built 12/86
    '88 L (VIN#55753) Built 12/87
    '93 GL one of the last Built 5/19/93
    what exactly is an ego?
      Exhaust Gas Oxygen Sensor nowdays all that we see are the heated ones (HEGO), O2 are a slang turm that has caught on. Mark my words "Someday you'll see O2 as the official name". Festivas are pre-HEGO, they all have little EGOs that you can see when you open the hood.
        Check rock auto.com and you can find the part number for replacement o2 sensors.
        Jerry
        Team Lightning
        Owner of Team Lightning
        93 L Lightning. BP
          $20 not bad.
            Get the Denso sensor, everyone here I believe agrees that it is the best one for the B-Series motors. Including the B3.
              I hava B3. how would i know?
                New Bosch O2 $14 AZone. Working just fine. Not sure what happened but now it is pegged @ .85~.89V, blowing black. Low idle speed, low VAC @ 13"Hg. Havent a clue what is going on. Gonna try a couple of Jager Bombs and look at it again.
                  Freud would be impressed!
                  Now, what about the ID?
                    warning, bosch o2 sensors are JUNK, and NOT recomended for J-pan cars. as stated earlier in the thread. given the information that you've exuded in other threads, one could assume that you'd know that already, but i guess not.
                      Re: EGO Problem
                      Cause people join forums to get advice on their vehicles only to go against that advice and wonder why things aren't working right
                      91GL BP/F3A with boost
                        ^ hey, it could happen....
                          I would quickly suspect the Bosch o2, except that I am getting my high o2 readings in open loop, even with the sensor disconected. I did see a post that said Denso only, but AZone only had Bosch, so I jumped on it for cheap. With the Bosch sensor the car ran marvelously for several 85 mile round trips into the Valley. Now my headache is keeping the o2 from working. the car is in open loop dumping massive amounts of fuel running rough with black exhaust. I'll keep looking for a denso just because you guys said so. All an o2 has to do is generate .1V to .9V based on oxygen content in the exhaust flow after heating to ~1400ºF. My exhaust mfld is not making that much heat. You know we can kill an o2 by what we make it sniff? Wrong silicone sealer on the pan gasket = dead o2. Antifreze down the header = same ..... Thanks for watching out for me, there is alot I don't know that you have already BTDT. So I look to your experience as a guide in my decisions. The Denso/Bosch thing was a moment of weakness. Can't believe I just wrote that.
                            it's all good, though i would start looking at your ECT sensor... if it reads incorrectly, the PCM will never go to closed loop and it WILL cause a rich condition.
                            you are correct in stating that the o2 swings from .1-.9, BUT actually the denso has a slightly higher center and can swing as high as 1.1v...
                            just saying that not all o2s are created the same.
                              Re: EGO Problem
                              Yup...even in open loop you shouldn't be that rich.
